Which engine oil are you using?
  • 0w40 (OEM)
    Votes: 91 40.8%
  • 5w30
    Votes: 3 1.3%
  • 5w40
    Votes: 17 7.6%
  • 5w50 (motul)
    Votes: 42 18.8%
  • 10w40
    Votes: 7 3.1%
  • 10w50
    Votes: 18 8.1%
  • 10w60 (Shell Helix extreme)
    Votes: 9 4.0%
  • 15w50
    Votes: 17 7.6%
  • 15w60
    Votes: 1 0.4%
  • One of these mixes or not listed
    Votes: 18 8.1%
  • Total voters
    223
61 - 80 of 88 Posts
how much oil do you need to do a complete oil change including filter on a R35 GT-R?
thanks.
5.5Ltrs if changing oil filter, 5 if no filter, however if you track the car you should fill to half way mark between max-min on dipstick and 5 ltrs will get you there even with a filter change
cars over 50k now so
Mobil 1 10W-60 Motorsport formula Engine Oil
Unless the engine has been badly worn due to the mileage (and 50k isn't a lot for a modern engine), there is no need for a thicker oil.
Tim
OEM Mobil 0w 40 fully synthetic oil here... serviced by Litchfield.
I read recently the main reason manufacturers run low viscosity oil is for better mpg, seen quite a few times the exact same engine having two different grades recommended depending soley on year of manufacture.
15w50 should be fine in summer, Motul 300v and Silkolene Pro-4 are very good oils.
Discussion Starter #71
Thanks for the reply,
My average mpg is same 27mpg doesn't really matter which engine oil in my engine. I am on 10w60 for five years now.
Manufacturers do often use thinner grades to improve fuel economy, but the benefit is pretty minimal. Most new American V8s tend to recommend a 0w-20, 5w-20 or 5w-30 and any mpg gain is going to be minimal, but across a million vehicles, it might be worthwhile.
It's not just for mpg though. Modern engines are built tighter than older ones, so a thicker oil will not flow properly around them, leading to reduced protection. Most of the protection an oil gives is due to the flow providing a film, rather than the viscosity of the oil, so what you really want to use is the thinnest grade that is suitable for the engine. Too thin and there will be reduced protection, too thick and the flow will be reduced. As thinner oils cause less internal resistance, they also lead to power gains.
Tim
any one used 05w60 race tech liquid Moly ? - as in what they put in modern Ferraris and such like..
its all I can get over here.
and how come only fill half way when on track ?
I was always told slightly over max...
its what we always do with our track and race cars.
now that mobil1 0w40 new life isn't avaible anymore what does Nissan recommends on using? seein as the new 0w40 from Mobil1 isn't as good anymore.
or to put it differently: which oil meets or exceeds the specs of the old new life?
Discussion Starter #80
I am happy with 10w60 runs a lot cooler on the drag strip.
We tried with two gtrs 0w40 vs 10w60 and oil temp was way too much different?
0w40 after few runs 107c
10w60 after few runs 80c
61 - 80 of 88 Posts
