Hi I thought I would try and gain some knowledge from people in the know as I'm still learning. I'm going to go for about 530-550hp and know I need to upgrade the fuel system. I recently bought a SARD FPR so I was thinking of 800cc injectors as they aren't a lot more than 700cc and would give me a bit of leeway. However I' not sure I have the right FPR now as I've found out that there are two types (standard and Type RJ) and I bought the standard type. Do I need to get the RJ for this hp target or will the one I have be ok.
Thanks for any advice
:thumbsup:
yes i believe you should have the rj type 800cc would be fine it gives you scope if you want more!! i think 1000cc and over can give issues at idle due to the size of the hole/s
one other thing the sard 800cc need different electrical plugs which you have to change over, whereas the 700cc just plug in, im not sure on other makes
Thanks! And bugger, trust me to buy the wrong FPR. :chairshot
Guess I'll have to sell this one now.
:thumbsup:
