1 - 8 of 8 Posts
hi i just modified my r33 gtr to around 550 bhp
can i use standard spark plugs or do i need (hks or blitz)plugs
and if i do which grade
what gap and heat range?
Or can anybody reccomend a part number?
8's with a 0.8mm gap is a good all round plug.
NikWilson said:
I am running about the same and using HKS S45's iridiums (which is grade NGK/Greddy grade 9). The car has been mapped using these plugs as well. Only a slight issue of cold starting but really great when warmed up. Using the pre set gap since you should never try to re-gap an iridium plug.
Use a heat range 8 or so NGK plug. Stock is a PFR6A-11. You can get BCPR7Eix which are a 7 plug pretty easy most places. You can get the NGK iridium 8's from Apex, and Greddy.
DO NOT USE the HKS /Denso Iridiums. I have seen at least 6 of the ceramics break off and fall down in the motor. I have NEVER seen a NGK plug do the same thing unless the piston hit it. The Densos are very fragile.
1 - 8 of 8 Posts
