One of my cars has a T88 and recently did the bottom end in (oil starvation).
At the moment it has Sard 700cc injectors which must be right on the limit as the car runs 1.6 bar and goes pretty well. Seeing as the new engine should take upto 1000hp I may as well run more boost. Maybe 1.8?
To do this I need to uprate the injector size as this is my weak link. 1000cc is the obvious choice but then maybe Sard 800cc.
What do you experts think? If 1000cc any particular brand?
Many thanks
Alex
i'm no expert, but Sard are resonably priced for what you get.
Ideally you would want injector that are flow tested for performance and matched as a set.
I'm sure the others will explain the more techinical side of this, hope it helps
