I'm thinking about being daring.
Ever since I knackered my rear brakes and my front during a day of excessive break wear (some have their suspicions), I've been considering replacing the rear pads and skimming the discs.
Has anyone tried skimming the discs ? Does one need a special tool to do both sides at once (to ensure both faces are parrallel)or is it satisfactory to just run a tool along one side and the the other. Can you suggest a pad for the r32 caliper?
I replaced the front calipers with r33 ones. Can anyone recommend a good make of pad? I think the current ones are ferrodo but can't remember the model number. Doyou know that aswell please?
Yours hopefully
charlie
I changed my standard pads for a set of PAGIDs from Hiteq before my last trackday. They were loads better than standard, but I managed to warp the discs in under 250 miles.
I have decided that I am going to upgrade to AP 6 pots, as in the long run I don't think it will work out that much more expensive than replacing the standard discs and pads every couple of thousand miles, but should offer infinitely better braking performance.
