1 - 6 of 6 Posts
I need wire up my knock sensors, but I'm not sure which side the wire goes to.
Can anyone help.
Skyline Section Manager
Look at the R33 wiring diagrams. That shows you.
From that diagram I'm still not sure which side they go in as I'm not sure what is meant to be the top or bottom etc.
Its the left side as you look at it from the front with the semi-circular cut out facing up.
I know what you mean, i reckon the three blocks on the picture represent the three locating lugs and matching notches on the connectors. Normally on the factory manual wiring diags the pins on the connectors are shown looking from the back of the connector (edit: thats to say the loom side). So the female connector held with the semi circle cutout at the bottom, looking at the back of the connector, the wire goes in the right hand side.
1 - 6 of 6 Posts
