Looking for opinions here for GTR. Particularly anyone that has done the install themselves. The Whiteline bush has an advantage that it has some adjustability - up to 1 deg - my car will need all of that.
The Cusco arm has one adjustment to lengthen the arm by 5mm, I read that this equates to 1 deg but I don't know for sure. For those of you who have the Cusco arm...did you get the 1 deg adjustment?
The Cusco arm uses metal bearings, so this will tighten up the feeling some and maybe increase noise or shock, however the Cusco is a bolt on solution whereas the Whiteline will take some work to get fitted.
Any and all opinions welcome...
