1 - 8 of 8 Posts
I have 18" Advan SA3-r's and the current tires are 255/35/18 The rim is 9.5" wide and 22mm offset.A 275/35/18 will fit in the back with no issues but will it fit in the front?The 275 is 1" wider than the 255 sooo 1/2" on each side.I have about 1" clearance right now from the shock.Does anyone use this size tire with the same offset ?I did some searching and it appears they will fit,I just want to see if anyone here is using a similar set up on their R32.
Well I took a closer look and the gap between the tire and the upper link is 15mm.I think I will keep the current size 255/35/18.I just bought these Bfgoodrich tires.
I use 18x10 with 285-30-18 on BNR32, no clearance problems at all.
The rear end was more of a problem than the front but guards have been pumped so all ok there now too.
You should be sweet with 275's :smokin:
1 - 8 of 8 Posts
