I use a stock turbo with an EGT and wideband AFR sensor in the stock turbo elbow after the turbo. I wonder if the casual use of a Bee-R limiter will damage the probes in the elbow? I'm not planning to abuse the gain button on bee-r, just normal limiter use. What's your experience?
normally u are sepose to mount the AFR wideband 1 meter after the turbo.if not, it can cause that u get inaccurate mesurments and will reduce the live from the sensor.
the Bee-R limiter can reduce the live from your sensor, but it will not be that excessive.
