1 - 11 of 11 Posts
Hi guys
i am getting my r33 gtr mildly upgraded. But i am in 2 minds about getting injectors for my car. Question is..will i need injectors at the power level i am chasing. 400 rwhp.
here are my mods:
internally stock r33 gtr with:
-garrett 2860 -7's
-pfc (non djetro)
-nismo intank direct replacment fuel pump
-slightly thicker fmic than stock
-2.5in front pipes, to 3 and 1/4 in cat back. hiflowed cat.
-stock dumps
-stock injectors
. car hasnt been tuned yet cause theres too many different answers for power outputs on stock injectors.
i heard this from someone but dont quote me on it.
apparently the r32 gtr's make less power than the r33 gtr's with stock injectors due to a different base line fuel pressure?? or something to do with the stock fpr??
Discussion Starter · #5 · (Edited)
i dont want to have to change injectors for another reason. Down here in Aus they are very strict on power laws and modifications. Im going with a stealthy setup.
For an extra 20whp should i just get a nismo fuel pressure reg?
And i have another question?
Would i need to port my exhaust manifolds with the -7's?
some say yes and others say its a waste of money.
i will never run boost past 18 psi on a stock motor anyway.
looks like i am going to see what the stock injectors produce as safely as possible.
if it does 380 rwhp il leave it. After all it is an internally stock motor. :)
im running 472bhp (393 athe wheels) with stock injectors on my r32 gtr.im running 1.1 bar with gt2860-5s i do have a tomei adjustable regulater.i wudnt push the boost any higher with stock injectors.Im running well over 90percent duty at this boost
easy way to calc how large injectors you should have is
HP x K
-------- = Fuel flow (cc per minute)
C
Where hp = maximum horsepower, K 4,6 for naturally aspirated engines, or 5,6 for turbo/superchargrd engines, and C= numbers of cylinders
400x 5,6
-------- = 373,33333...fuel flow (cc per minute
6
373cc is what a 6 cylinder, 400 hp gtr needs every minute per cylinder
TF x 100
Injector static flow(cc per minute)= ----------
N x M
Where TF = theoretical flow, N = number of injectors per cylinder , and M=
injector duty cycle
Best duty cycle is somewhere between 60-80%
TF= 373
N= 1
M= we take 70% for now
373 x 100
----------- = 532 cc/min
1 x 70
So you can buy 500cc injector or 600cc you get lower duty cycle on the 600cc
1 - 11 of 11 Posts
