1 - 10 of 10 Posts
Generally its a good thing to replace worn out rubber bushes with the above items as they tend to perish over time, they should refresh your cars handling.
I would say though its quite allot of work to replace bushes, as the old ones will need to be pressed out and in some cases burnt or cut out. But stick with it and you'll be happy with the results!
bob
the tension rods allows you to move the front wheel forward and hence more stability i think, however, with the bearing types i find that apart from smooth roads and tracks, it crashes into speed bumps and pot holes rather than ride over them, am looking to replace mine again as soon as funds allow.
1 - 10 of 10 Posts
