Afternoon all, will wheels in 18x9.5 with an offset of 20 and stud diameter of 114 fit an R33 GTR, I spose the rears will, but what about the fronts? too wide? and if they are can you get wider front wings for a GTR? I'd love big fat 245's and 285's on it.
i had 20inch alloys on my R33GTR 10j's with 255/30/20 all round and they fitted ok, totally messed up the handling but looked different, and ran a 12.9 at 370bhp on the 20's.
trust me and stick with the same size tyres all round pref 275/35/18 in your case if you have different size tyres it will mess your 4wd up and the 4wd light on the dashborad will start having a fit.
ive now got 17" blitz wheels on mine but with spacers as the offset wasnt right, H&R do some excellent kits PM me if you want more info on the spacers.
People did tell you about 20" and the adverse effects but did you listen?
Max size would be 19"s that will ensure the handling still stays ok. People say you shouldnt use more than 17"s on a 32, I dont understand teh logic behind this the later model also had 17"s and people use 18's and 19"s all the time.. I Personally think that on any GTR 18's 19's would be fine as long as you get the correct offset.
what tyres you running, does it turn in OK? and will it still slide about with that grip? I spose it's alot better with more grip as I must admit my car does understeer a fair bit on roundabouts etc before the rear breaks traction.
I get full turn lock to lock. Running the Falken FK451`s that i got hold off before they stopped making them...Now make FK452 instead which arent meant to be quite as good.
well i always like to try different things thats why i went for the 20s, personally id stick with either 275 or 265 and you should be fine on the turn in and lock to lock it will still slide if you push it hard enough but in the dry it will grip very nicely, ive got michelen piolet sports on mine and they are far better in my opinion than the bridgestones i had previously. JUST make sure you have same size tryes on all round, dont listen to what some tyre fitters will say i.e "275-45-18 on the rear and 255-40-18 on the front will be fine" they wont trust me ive gone through 4 sets of alloys and 6 lots of 4 tyres and now im happy with what i got.
Oh no, not the tyre and wheel size debate all over again !!! Nissan spent an absolute fortune on marrying the correct wheel size with the engine, gear ratio’s drive and transmission and now your gonna fcuk it all up with bigger wheels and tyres!!
Ok Ok Ok, if your gonna be a show off then big shiny wheels are nice, but if your going to any serious track work stick with what Nissan recommended and put on the car !!
Use the below calculator to see how much more it moves out.
I used 10.5 +15 as a guide as thats what NISMO has made the wheels to fit. In my opinion, that is still quite conservative (if what you are asking is a absolute maximum).
As per above, what your going for is pretty conservative, so you will be fine.
Im running ET20 10x18 and 265/35 on my GTR and TBH i still might add some spacers to bring em out a lil more...
Related Threads
GTR Forum
2.4M posts
69.2K members
Since 2001
A forum community dedicated to Nissan Skyline GTR owners and enthusiasts. Come join the discussion about performance, mods, troubleshooting, body kits, classifieds, maintenance, and more!
