1 - 6 of 6 Posts
Went on holiday
came back battery was flat
so i correctly set up the jump leads and the car started fine
Dont know if the jump caused it or just locked over the 2 weeks in it was in my garage
Since then my passenger window doesnt open
Where is the fuse? Fuse number/position cant seem to find a broken fuse
Help?
What could it be?
Switch, motor, fuse?
Makes no noise just nothing from drivers and passenger side
Is it drivers side or passenger side, or both... this happened recently on my R32, passenger window wouldnt close from passenger side, but would from my side.. switch cleaner sorted it out.
just silly question but have you checked you havnt pressed window lock button? just up from window switch.
Oh my god!
LOL
Your right !!
How silly do I feel
I never knew there was one LOL
My old man moved the car in the garage must have pressed it when he moved the mirrors in
never even thought to check it!
Problem solved! :)
1 - 6 of 6 Posts
