Although the OEM Bridgestone and Dunlop are classed as Summer tyres I used OEM rubber for 3.5 years covering nearly 60k and never had any issues with them, so long as you treat the car with respect when wet/snowy/icy you should not have any issues.Winter Tyres needed or not?
Exactly the same here. Although I've not covered as many miles !Although the OEM Bridgestone and Dunlop are classed as Summer tyres I used OEM rubber for 3.5 years covering nearly 60k and never had any issues with them, so long as you treat the car with respect when wet/snowy/icy you should not have any issues.
I presume you use winter tyres then? Which ones pleaseSounds like the answers if people who haven't used them.
You have the choice, would you like more grip and better wear rate in the conditions or less?
Why compromise when you don't have to?
The cost is just cash flow. You are buying your next set of tyres now and as result your current set will last longer and you gave better tyres in the conditions as a result.
Winter tyres have more grip below 7.5 degrees, especially if there's moisture on the road. They cooed better with standing water and on snow if even ice they are immeasurably better.
Given the choice if trying to climb hills in very low temps, I'd choose winter tyres before 4wd.
I used mine extensively for the last 3 winters and as I mentioned covered nearly 60k miles in that time, I was not a fair weather GT-R 2nd car user so I take a little offence at your comment above.Sounds like the answers if people who haven't used them.
Yep, I concur !!!I used mine extensively for the last 3 winters and as I mentioned covered nearly 60k miles in that time, I was not a fair weather GT-R 2nd car user so I take a little offence at your comment above.
I do agree that Winter tyres are better in low temps but I would not use them in this county as the times when the ambient temps are low enough to justify the purchase price are not as frequent as people might think.
If he is doing low mileage and only wants to purchase one set of tyres then OEM will be fine so long as you set the correct tyre pressures and don’t drive like a dick.
must resist..........don’t drive like a dick.
Dick 100%Yep, I concur !!!
Dick or not dick !!
You can't convince some people Adam.Winter tyres are not snow tyres, they are cold weather tyres and have more grip on snow AND even ice.
I do agree with the above though, I don't use them on the Gtr as I prefer to use an alternative car in low grip conditions because of other drivers. If the Gtr was my only car I'd switch to winters. They do t cost more money, they only cost cash flow!
David, 4WD does a lot uphill but is no advantage when trying to stop.
