Okay, so after doing some research, I've come to the conclusion that the HICAS still works as well as the speedometer if you cut wire #53. The questions I have is about the power steering. It is supposed to be speed sensitive. The higher the speed, the stiffer the steering. Is this affected if you cut that wire? Is all power steering equal afterwards?
