Somehow chipped a tooth on my front diff gear... Anyone have a front GTS4 ring and pinion to sell? I forget what the ratio is but it's around 4.36 or 4.4:1 but it has to be from a gts4 so I don't have to guess what is compatible. Will pay shipping. Located in Canada.
I checked my sales history as I sold similar to a guy in south africa. The diff you ask for is a 4.375 (35:8) and the ones I have is a 4.363 (48:11). Having 11 on the pinion makes it a lot stronger than the R32 diff you ask for.
I can sell you a front + rear combo as I have both.
I don't have the 4.375
regards
Arnout
regards
Arnout
The rear is fine and so I don't need the additional cost of the rear diff, the labour to remove/install/set up and whatever mods would be needed to fit the 34 diff.
Sadly I just need the 375 front!
