Hi all,
Before anyone says it - i have done plenty of searches but have tried all of the stuff already...
I have an intermittent misfire when off boost between 2500 and 400 revs on light throttle.
I have checked the plugs (iridiums), cleaned the AFM's (nismo's), tried switching off the 02 feedback in the power fc, have splitfire coils, checked that no intercooler pipes are off, replace the ignition amplifier, checked injectors etc...
With the fault being intermittent it is proving hard to track down, it seems to clear out when you give it a blast but then returns after a while on light throttle at low revs (my tuner said that on the dyno the A/R looked fine)
Does anyone have any suggestions as to where to look from here ? any methods i can use to track down what is causing the fault ?
Any help is massively appreciated,
Pete
Pete
