What is your engine displacement now or your next project for sure
  • 2.6 stock internals
    Votes: 31 38.3%
  • 2.6 forged internals
    Votes: 15 18.5%
  • 2.7 forged internals
    Votes: 7 8.6%
  • 2.8 forged internals
    Votes: 10 12.3%
  • 2.9 forged internals
    Votes: 1 1.2%
  • 3.0 forged internals
    Votes: 13 16.0%
  • 3.1 forged internals
    Votes: 5 6.2%
  • Stock head
    Votes: 8 9.9%
  • Mild head work
    Votes: 13 16.0%
  • Wild head work
    Votes: 12 14.8%
1 - 17 of 17 Posts
Since I am doing some R&D for Bullseye Power I wanted to know what is your current motor displacement and is it with uprated internals or what is your next motor setup (if you know for sure).
Please pick a bottom end and head option
I currently am asking RIPS to build me a 3.0, but during the in between time I will be building another motor for R&D. I will try to do as much turbo comparisions as possible (this is out of my pocket) against the Bullseye Power Turbos to see what will flow better.
Any input would be appreciated.
I am willing to try anything within a budget. I currently have the following items to work with more to come:
Jun intake manifold with a Q45 throttle body
Greddy manifold
Stock Manifold
Stock exhaust manifold
Custom top mount manifolds with T3 flanges (can get T2-T3 flanges)
Working on a custom T4 manifold
Stock R34 turbos
HKS 2530's turbo
working on getting a T04Z
HKS 264 in and ex cams
HKS Step 2 272 in cam
HKS Step 2 280 ex cam
Tomei 280 11.50 lift in and ex cams
Tomei Type C springs and retainers
Tomei lifters
HKS step 2 springs and retainers
HKS 100mm exhaust with Cat
ARC 100mm titanium exhaust with no cat
Nismo downpipe 2 x 70mm-80mm
ATTKD titanium downpipe 2 x 76mm-80mm
Stock 02 housing (extension)
ATTKD 76.5mm o2 housing (extension)
Custom 3" o2 housings for S200's
Factory FMIC
Greddy 5 row dual inlet FMIC
Stock R34 444cc injectors
Nismo 555cc injectors
RC 750cc injectors
RC 1000cc injectors
2 Greddy fuel rails
Apexi 280lph pump with custom swirl pot and Weldon pump
AEM EMS with Map setup
John
RIPS have experience on building 3.0's and they are having custom work done and custom parts made for my needs :smokin:
John
I've got a complete head, an empty block, and an oil pan left over from my rebuild. I figure my current refreshed engine should last me at least long enough for me to bore it out to 2.8, collect and install forged internals, and work on the head - basically my idea of a dream engine. Hopefully I'll be able to build it myself as well - that would be enormously satisfying.
I just bought a new factory longblock from Japan for $5600 CDN shipped and added TD-05-16g turbo's.
.8 bar of boost by 3800 rpm.Boost controller to follow.
new parts added
-Nismo single plate clutch
-HKS bov's
-HKS pods
-Apexi fuel pump
-Samco hoses
-Trust downpipe
-3 greddy 52mm gauges
-Mines ecu
-Splitfire coils
-Fujitsubu 3" exhaust
-18"Adavan SA3's
-Momo GTR gear knob
-all new hoses,belts, yada yada
Are you serious? That's a very good price.
Definately keep us updates :)
John
HKS 0.5 overbore pistons going in on the 6th....so 2.7. Wish I could swing the 2.8 but it's not in the cards this time around, plus all the N1 blocks I used to see everyday went AWOL
It'll be standard rods/crank/head and T517z's 8cm.
How have the turbo comparison's been coming, if at all?
:eek: well, I'm having to look at this a lot quicker than I thought -
My ideal spec would be: R32 block, R33 crank, head from either, forged pistons, uprated conrod bolts, uprated bearing shells, Tomei Poncams, stock exhaust manifold, hard pipes, stock FMIC, GT-SS turbos, and supporting mods.
Will look at the Tomei complete engine offered to me tomorrow - sounds groovy. bad luck, but then good luck:squintdan
Thats nearly my exact spec,except i have an uprated fmic and a pair of garrett gt28/60's :chuckle:
christ, that's not confidence-inspiring, as my oil pump is an N1. How long did it last before it broke?
well I know exactly how many miles I've put on my pumps (1500) so I guess I can trust them for a bit.
One thing breaks, the whole thing goes. <sigh>
1 - 17 of 17 Posts
