21 - 24 of 24 Posts
Discussion Starter · #21 ·
Hi Paul, cheers for that - whats your PB for a complete run that I can use in the time being? The low trap speed is the main bit I am looking for and if its stuffed by you not getting a gear then it makes the result a bit useless :(
its run 144MPH on a bogged launch and ran 10.0 so that info is pretty useless too. Im running the car again next weekend so ill hopefully have some better data for you.
PB for the low-mounts was 9.95 @ 139 but i was holding 3rd gear at 9K and not shifting into 4th to avoid exceeding 140MPH because i didn't have a chute fitted. So that data is a little flawed too.
Discussion Starter · #23 ·
All good, thanks :) Will keep an eye on the results, anyway. Sounds like its going really well with that big single!
Drag-r 9.4 @ 155mph 1740kg
21 - 24 of 24 Posts
