I seem to be having a Maf issue at the moment, with the car running like its on 5 cylinders.
On the Apexi what voltage should be showing on idle and normal driving?...
Depends on your setup, turbos, cams ect. With 264 cams, and PE1520 turbos, I see around 1.08 volts at idle. Fluctuates a little but seems to be around .9 to a little over 1 volt.
