1 - 12 of 12 Posts
Can anyone tell me the difference between the RB25 and Z32 AFM please?
Are they both 80mm diam?
Does anyone have the part no of each of these?
thanks in advance.
They are both 80MM.
RB25 series 1 AFM has green label and part no. 22680-02U00.
RB25 series 2 has a pink label, not sure of the part no.
Z32 has an orange label, part no 22680-30P00.
Pink - 22680-31U05
It's the one I have on my R34 GTT.
Is there anything to gain from using a z32 afm v. oem on a basicaly standard car?
so, simon, what have you heard is the actual max hp that the stock afm can handle. I've heard everything from 300-350hp.
I have an AX53B70-25 turbo on the way which at 0.8bar should give me around 320hp with my current setup. Do you think I should go with the z32 or just order a new rb25 afm sensor? after all the old one is probably starting to give.
Cheers!
Tomas
ER34GTT - I'd sell your RB25 AFM and buy a Z32 one as the RB25 will be running out of tuning capability by 320hp. The Z32 will let you carry on if you want upto 420hp (+/- 20hp)
RB25 ecu and maf
I have a RB25 in my R32, running on a chipped ecu. But was tuned on a z32 maf. Right now I have a RB25 maf on it. What will be the down side if this ?
the z32 will flow way more than that figure i have one on my pulsar at 432 hp its only at 4.3 ish volts
people reckon its more like 500 hp
1 - 12 of 12 Posts
