I'm assuming that the greddy has 2 ports?
Options are as follows:
2 port:
a. One feed from the cam covers and one used for atmospheric breather
b. One feed from the cam covers and one fed back into the induction pipe
Either way, these are the directions:
1. Remove the short hose which runs from the LEFT (n/s) cam cover breather to the induction hose. you need a 22mm rubber cover for the cam breather and a 18mm plug for the induction hose. Both should be clamped in place.
2. Remove the 'L' shaped hose which runs from the RIGHT (o/s) cam cover breather to the bypass valve on the balance tube (next to the fuel rail).
Blank the bypass valve with a suitable rubber cover (sorry, can't remember the diameter) and jubilee clip.
3. Connect a long hose (22mm inner diameter) to the RIGHT cam cover breather and then connect to your catch tank using a suitable adaptor.
like this:
Or, you can tee the two cam breathers together like this and remove the cam cover link hose:
4. On the catch can second port, connect either:
a. A small filter to atmosphere.
b. A hose back to the induction side (which i told you to blank off)
c. A hose to atmosphere, but this has the disadvantage of dripping on your drive.
Note:
Many people do not complete step one of these instructions and hence they never find any fluid in the catch tank (because all the vapour is taken to the induction pipe and not to the catch tank!)
I'd post some pics of my car setup, but right now my engine bay is empty!
Good luck
Ian
