I have to day Pulled the HICAS Fuse, as the car wasy trying to steer the rear wheels, while I was doing about 70-80 MPH,
This is an on going problem, but to day I had had enough so I disabled it
I quite like it with no HICAS, I have had it checked with the Nissan consult and the system seems fine, but every so often it "twitches" (Even with the RADIO OFF) the "twitch" is not to bad
but when it seem to be swereving me to the central resivation and then trying to make the rear of the car change to the inside lane it is not good.
I have another HICAS ECU To try, as I have elemanted the G sensors and speed signel etc...
Any similer propbs advice would be welcome
I also Had a R32 and the HICAS and ATESSA Worked much better in KM's
Nigel
