For sale is a brand new ATL fuel cell
Capacity is 45litres and is foam filled and comes complete with all gaskets, instructions, and FIA certificate
It also complete with a gated anti-surge bladder which was purchased as an optional extra at the time
The cell is FIA approved, but has now expired; it came with a 3 year certificate, but I believe you can get it checked to get the certificate renewed or extended 2 years at a time
I took the cell apart for the photos, to show what its made up of
Blurb from website:
The ATL Saver fuel cell range is manufactured from a unique ATL565 material. Each one is supplied fully foam baffled to help reduce fuel slosh and suppress explosions. Fitted with a 6***8221; x 10***8221; top plate which includes the following fittings-
2 x -6 JIC fuel pickup/return
1 x -6 JIC rollover vent valve
2 1/4***8221; Diameter non-return filler neck with integral valve.
The ATL saver cells are suitable for use with carburettor based fuel systems. To enable use on a fuel injected system, an external fuel catchtank / swirlpot would need to be fitted.
Please see link below for further information:
ATL Saver Cell - Demon Tweeks
Cell cost me just shy of ÂŁ700 at the time (ÂŁ575 for cell and ÂŁ125 for bladder)
Cell comes complete in original packaging, but box is a little tatty from storage; as seen in photo
ÂŁ375 including courier p&p
Ade
Blurb from website:
Ade
