BNR32 Nismo upper front arm bracket vs OEM
1 reading
4.2K views 8 replies 5 participants last post by  markM3
#1 ·
As can be seen from the pictures the difference between the Nismo upper arm vs OEM is apparent. The purpose is to correct any twist due to increased caster. Camber also appears to be gained by a combination of both longer lower arm - offset outer joint hole by 5mm and offset position in the top arm bracket. Will get some measurements when I can find my measuring caliper.
#4 ·
i havve the complete nismo part list under mine.
from these brackets, upper front arm, front lower control arm, tension rods, rear arms front upper rear and lower control arm, hicas removed with Midori seibi.
Everything is nismo, and the change is huge, better grip, and in turns more stable.
Caster, camber everything changed in the better way. There's no other way then Nismo suspension
