clutches , pull / push ?
6.4K views 7 replies 6 participants last post by  TREG
#1 ·
hey guys just a quickie ive got a 34 gtr and am going to be needing a clutch very soon , dose andone know what sort i need pull or push ??, i dont understand the whole thing all i know is there is 2 types ?
cheers chris
#2 ·
R34's require a different clutch to a R32/33.
It is a pull clutch, but just order it specific to suit a R34 GTR.
I would recommend a Nismo Super Copper Mix twin plate.
#4 ·
You need a pull clutch. Some clutches are only available as push, even for R33 and R34 applications, so a push conversion is required. A push conversion is not that expensive nor difficult, but for the least hassle a pull clutch will be best for you.
The Nismo Super Copper Mix Twin is a pull clutch for the BNR34, and is a great clutch!
#7 ·
i have a single plate copper mix and a light weight Nismo fly wheel i took out of my 34. Its done 1000 miles i think. Was changed before i purchased the car and i replaced it 300 miles later. Welcome to come and inspect before you buy. It does need a new thrust bearing tho, about 30-40 quid.
Make me an offer if you want it!
O and its a direct fit, no pull/push convertion needed
however, i would not be worried about the converstion if you choose a different clutch. Its only a bracket that different and a couple of bolts. Most clutches for a 34 will come with the bits to use either way.
#8 ·
Blooming heck mate-the cars wanting a bit done!
The copper mix clutch is the one that I am after when my clutch goes.
Endlessr also do them used on here.
