R32 GTST problem
1 reading
5.4K views 18 replies 6 participants last post by  garage pink
#1 ·
Hi all
just brought a gtst and everything was sweet until i drove it tonight
car idles and drives normally but if i boost the revs drop right down as if it has no fuel, obvious checks are fuel pump which is on as i can hear it and there is half a tank of fuel
any help would be good
cheers
#3 ·
was going to do all 3 tomorrow, dont think it would be an air leak as its fine until i boot it, on a brief check under the bonnet the fuel filter did look old so gonna try that and maybe some redex to clear the injectors out
#12 ·
When doing my afm I sprayed some carb cleaner through it and that cleaned it out.
Iv just had a search around for you and there was a guy with a 32 gtst and his hesitation was related to the following I no it's not the afm but worth a check:
"I took the coil pack wiring loom off into the house to check for breaks/shorts, thats when i noticed the actual plug casings had degraded so much that there was arcing/shorting or something going on (blackened wiring) because in the plugs the plastic that separates the connectors had split showing bare metal, got a few new ones and its been fine ever since. have a look you never know."
