Standalone emerald ECU for RB26 with loom and coils
1.1K views 2 replies 2 participants last post by  Seg
#1 ·
Standalone emerald ECU for RB26 with loom and coils.
This was used on our supercharged RB30 which unfortunately never saw the light of day. But the engine management ran with no issue
This is the car running on below ECU with HKS/DENSO 1000cc injector:-
First (public) Start-up of Supercharged RB30 - S15.3 EDC Drift Car - YouTube
Unfortunately I had to cut the loom to get it out of the car but the wire colours are unique so it will be easy to reinstall. The only missing parts are the fuel pump relay which was left in the car.
The ECU was setup to run with EVO coilpacks, these and the mounting brackets come with the ECU. I may well work with Nissan coils if they are positively switched.
The loom contains ballast ressters to do away with the need for the standard injector pack and will work for all drop in RB26 injectors
It also comes with 3 bar Map sensor and I think there is a boost controller but will need to confirm.
It wont run with CAS, so you will need to add a 36-1 or similar crank wheel I think you will also need a crank sensor as this went with the short engine.
It works with stock nissan throttle potentiometer and temperature sensor.
The ECU can run closed loop wideband if you have a guage/controller with 0-5v output to feed into the ECU.
ÂŁ575 posted
