Hello all, I just finished restoring a set of RB26 ITB's, media blasted, all parts yellow zinc plated, new seals, esc. Even though there is barely any light showing past the plates, id still to apply dry film lubricant to create a better seal around the shaft and any openings that may be there. I dont have access to the actual Tomei throttle coat, but I have something from my aeronautics job that is likely the same. I could use some guidance on how it is applied, as the Tomei instructions are nowhere to be found online. I have seen some pictures in forums, but nothing instructional or detailed.
-Which side of the throttle plate is it applied?
-are you supposed to open and close the throttle plate repeatedly after application or do you let it dry?
-do you apply a mold release agent or PVA to the plates so the moly does not stick to the plates?
Thanks everyone
Thanks everyone
