Looking for new clutch as taking the car up to about 550-600 via a single turbo conversion. Looking at mainly os giken ones i have heard nothing but good reports.
Problem.
ive been looking on greenline as thats where i get most me stuff and they have about 3 different options:
OS Giken TS2B LOSR32C001
Twin Plate push type clutch. Steel press cover. 204mm. 9,800N/m (1,000kgf/m). Models after 93/2 require fitting kit.
OS Giken TS2BD LOSR32C002
Twin Plate push type clutch. Steel press cover. Damper type. 204mm. 9,800N/m (1,000kgf/m). Models after 93/2 require fitting kit
OS Giken TS2CD LOSR32C003
Twin Plate push type clutch. Steel press cover. Damper type. 215mm. 9,800N/m (1,000kgf/m). Models after 93/2 require fitting kit.
done a few searchs on forum found a lot of info on them but not a lot i understand.
which ones are most commonly used and if anybody is using them with the same kind of power, which one do you have.
thanks
Problem.
thanks
